I have ffmpeg-win-2.2.2 installed in the correct place and i have tried manually locating it within the program but it has automatically located it correctly.
.aac files still won’t open, i get:
without the optional ffmpeg library audacity cannot open this type of file.
Try opening a WAV or MP3 file, and see if you can export it as M4A/AAC.
If that works FFmpeg is at least partially working and, maybe there’s something wrong with your AAC files. Try checking one of the files with [u]MediaInfoOnline[/u].
Note that for Windows, the manual says to use the FFmpeg “EXE” installer rather than the ZIP version.
Note that for Windows, there is a 32-bit version of FFmpeg and a 64-bit version, and Audacity is available as 32-bit or 64-bit. Ensure that you download the version of FFmpeg that matches your version of Audacity.
If you follow these instructions and still have problems, start a new forum topic and ensure that you include:
The exact version of Audacity you are using
What operating system you are using
The full and exact file name of the FFmpeg installer that you are trying to use
