FFmpeg (0.6.2 OSX 10.4+ DMG) + LAME MP3
I have tried to download the above library about 25 times to no avail! I try it from the audicity web page - I try it from the preferences library page but find it impossible - what am I doing wrong?
Please follow the instructions on this page: http://manual.audacityteam.org/help/manual/man/faq_installation_and_plug_ins.html
Download of these libraries is not from the Audacity web page.
– Bill
I have tried to do it from this link - it is for a MacBook Pro OS X 10.7.4 and everytime I download and return to preferences and browse and ok it never appears!
Try the Alternative zip download for Lame 3.98.2 http://manual.audacityteam.org/man/FAQ:Installation_and_Plug-Ins#maclame_zip
and “Alternative zip download for FFmpeg 0.6.2” http://manual.audacityteam.org/man/FAQ:Installation_and_Plug-Ins#macff_zip
I have tried the above yet again and posted same to my desktop but still not possible to import to the library. I open preference and press browse and locate on my desktop and and press ok and nothing happens. What am I doing wrong.
Thank you for your help
When you double-click the zip file it should create a folder called “FFmpeg_v0.6.2_for_Audacity_on_OSX”. So is that what is on your desktop?
– Bill
it says it cannot execute binary file??? I have tried everything but cannot import Lame or FFmpeg library! Why Why Why?
Are you trying to double-click one of the files inside the FFmpeg folder?
– Bill
