Feedback when starting to record from turntable
Beginner question!
I plug in my connection from turntable to laptop to record albums. It will work at first. After a few recordings, the next time I open up the application I get a “Feedback Sound” that does not allow me to record.
I have re-installed & still get this issue.
Is anyone getting this issue & how to connect correctly. Reminder - I need “beginner” instructions.
Make sure to directly select your input device… The USB turntable, line-on on your soundcard, etc. Do NOT select anything that says “loopback”.
Thanks for the assistance.
Quick question - Where do you “select your input device” for the USB Turntable? I have gone through the menu but not seeing it.
Sorry & thanks!
Tom
Make sure you’ve selected the correct Audio Setup
