Hi, its me again, frozengamer. I have a question, how can i cause feedback on purpose? I wanna make noise music and avant garde, so how do i cause noise on purpose?
Do you mean the feedback squeal you get from a PA system?
You can try Generate → Tone. Maybe a sine or square wave at around 4kHz?
Create a new track with Tracks → Add New first to generate the tone in a separate track.
When you play or export, it will be mixed with the original track.
You can use the Envelope Tool to fade the “feedback” in-and-out as desired.
Yes, but i also want stuff like no input mixing, I’ll try this!
