Feedback on Audacity 4
Hi, I am kinda new even though I use the Audacity 2, it was a bit confusing of all the interfacing stuff to the point where I just want to sound edit and use a few plugin, to make it unique as I cut pieces of the sound, seeing this version of Audacity 4 is very user friendly and gives some custom theme on the UI, I like to suggest if its possible to present more color UI tones like Navy blue, Obsidian, or amber color UI or customize choices to user decision, that would be really cool to have, aside from that, I wonder if you can add some tooltips of suggestion of what the plugins can do when choosing them since most plugin, I am not sure what they do to the sound, so maybe some context can help in that area. Another thing I was thinking is the fading in and out, can it be option when I right click the beginning of a track or at the end of the track that I place a fade in/out to the track as am easy option to find then going through the tabs to look for one? Other then that, this is a good change of how far you guys improving audacity, also don’t hesitate the changes, I am satisficed of how it looks as long its user friendly and I am able to edit sound, it should be a good to go from there, continue to surprise me of new features that benefit both sides.
oh forgot to ask this, is there no OGG format when exporting sound?
The current version is 3.7.7 (I am still using 3.6.4). Audacity 4 is in an early alpha (not even beta) phase and full of errors, some things even not implemented at all, and only for testing. Do not use it for any productive work.
I only using it just do small stuff for editing sounds, I dont have a big project for using Audacity 4 alpha version, but I do like to give some feedback for using their software and some suggestions.
It’s in the current version (3.7.7) so I assume it will be included in version 4.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
