Audacity Version: 3.1.3
Operating System: Windows 10 Pro
Microphone: Fifine K669B
Computer: MSI Notebook PC (Model No. MS-16GB)
Setup Details:
Laptop sitting on table with USB microphone plugged into laptop, speaker standing 1-2 feet away. Recording using OBS, with an “Audio Capture” source ported directly from the USB mic.
Issue:
Within the audio of a recorded video of normal speech, there are random sets of very fast, somewhat quiet popping noises, (they sound like a drum pad being hit over and over at about 700bpm), and I don’t know their source, how to remove them post-recording, or how to prevent their creation upon further recordings.
Issue Details:
I have attached an example of the noises randomly popping (haha) up while I’m saying something, and also the Audacity waveform of that sample (the popping is only visible at the beginning, before the speaking starts, appearing as five small spikes in the audio). You may have to turn your volume up to be able to hear them. The popping happens about once or twice every couple of minutes, within a fifteen-minute video, and seems to only happen when I speak particularly loud, although it persists long after the loud volume has ceased, so I don’t think it’s clipping noise. Also in the sample, another issue comes up near the end, where the audio gets all glitchy, but that’s the only time that happens in the recording, so it’s not as big a deal as the popping.
Attempted Fixes:
I tried all of the proposed fixes for clipping I could find, including Clip Fix, Click Removal, and High Pass Filter, and none had any effect on the popping sound. (Repair might have worked, but to apply it would have taken hundreds of hours to cover fifteen minutes of audio.) Recording circumstances only allow rerecording once every couple of weeks, so it would be much preferred to find a post-recording fix so I can save my current audio, but if this is not possible, simply finding a way to prevent popping in further recordings would be amazing. Thank you.
