Failed to open Database file Macbook Pro
Hello, my .aup file is corrup with a database file error, i was working on it and my PC crashes so I forced exit and… now the archive is corrupt… i dont understand it please help!!
You mention an aup file. Does this mean you are using version 2.x of Audacity or are you referring to an aup3 project file?
Mark B
Yes, it’s a aup3 file
Sorry, after more than an hour of downloading from your Google Drive link the download failed. The best thing I can suggest is to find a friend with a Windows (or Linux) PC and give/send the project file to them. You can copy the file onto a USB stick or external drive but it must be formatted as something other than FAT32 because there is a file size limit of 4GB on FAT32.
Once they have the file on their system they can use the instructions here: Fixing corrupt aup3 project file.
I hope that helps and you can fix it.
Mark B
Update: I tried again and was able to repair the malformed database. Deep joy! This audacity repair tool thingie is a bit good. :wink:
