Continuation of the topic:
I received the cable usb - AV 2 RCA and connected to laptop. But Windows persistently doesn’t see it.
Does the turntable have a built-in pre-amp?
If so, is it on?
What “cable usb - AV 2 RCA”?
What does your picture show? A turntable usually has no aux-in.
Please supply detailed descriptions (make, model, etc,) of all equipment involved.
Best way is to connect your turntable to a standard amplifier and go from the amplifier’s “line-out” to your computer, using an “external sound card”.
If Windows can’t see it (for some strange reason) it’s not going to work with Audacity. ![]()
You said in the other thread that you can record to a thumb drive. Maybe you should reconsider using something that works. ![]()
