Fading Effects
Olá!
How can I use Fading Effects on my MP3 tunes???
Of course you can Fade-in or Fade-out, or whatever… Exactly what do you want to do?
A quick note about MP3 -
As you probably know, MP3 is lossy compression (information is thrown-away and changed during the compression process).
When you open an MP3 in Audacity or any '“normal” audio editor it gets decompressed.
If you re-export as MP3 you are going through another generation of lossy compression.
MP3 isn’t “terrible” and you may not hear any quality loss, but the “damage” does accumulate.
It’s best to work with lossless originals and compress once as the last step ( if you want MP3). Or if you don’t have a lossless original, try to minimize the number of times it’s compressed/re-compressed.
Or, there are special-purpose programs such as MP3directCut that can do limited editing without decompressing.
