Factory presets for reverb settings changed in v 3.6.1?
It looks like at least the names for some of the Factory Preset reverb option changed in 3.6.1.
Does anyone the equivalency of the new vs. the old names? For example, is the “Large Room” preset in 3.6.1 the same as the “Large Hall” preset in earlier versions? Or did the parameters change too?
Large Room has not been changed in the past 8 years. Are you using a translation? Maybe a translator found a different translation more appropriate.
Most presets not named after room sizes have been added in 3.6 and did not exist before.
