I need to get the choruses of 300 songs. How can I do that using chains?
I’ve tried adding all songs into one project, labelling each and doing “Export multiple” but the only options available was to export using labels or tracks. Neither weren’t able to get the choruses.
Unfortunately you can’t do that with Audacity because Chains do not support “Export Multiple” and don’t support “Analyze” effects.
It “may” be possible to automate the process using a third party application such as AutoHotkey (https://autohotkey.com/). I don’t use Windows so I’m not able to help with using AutoHotkey, but I’ve done similar things on Linux using “Autokey” (the Linux equivalent of AutoHotkey). One tip that may be helpful for writing an AutoHotkey script - insert pauses between each command to allow Audacity enough time to perform each operation.
