I have a soundcraft notepad 8fx mixer hooked up to my laptop by usb. The mixer is coming up on the speaker menu but the mic I have hooked up to the mixer is not coming up in the drop down menu. The mic is a Rockville rmc-xlrz. Please help! Thank you!
If the mic is a condenser type and your mixing board does not have phantom power, it will not show. Here are some steps from my Audacity101 guide that you might try:
OPTION 1
Start → type in “troubleshooting” (without
quote marks) → select “Troubleshooting”
from the list above.
Under H’ware & Sound, click “Troubleshoot
audio recording” → Next → select the
device you wish to troubleshoot → Next →
Apply this fix.
OPTION 2
Start → Connect to Internet → All Programs
→ launch "Sound Recorder.
Press F1 key (or click “Help”) → scroll to
bottom → select "Troubleshoot audio-recording
problems → “Fix it.”
Run (to download and run a Microsoft app
called “Mats_Run.AudioRecording.exe”) →
install the app → Run → “Detect and apply
the fixes…”.
Select to troubleshoot “Microphone” → Next
→ Close. If problem still persists, try mfr
forum.
OPTION 3
Start → type Device → Device Manager →
expand "Sound, video and game controllers.
Right-click on any duplicates and Remove
→ Action → Scan for hardware changes →
exit.
Adjust Windows’ speaker volume: Click on
speaker icon in system tray (lower right
corner near clock) → drag faders to, say,
one-third of the way up.
NOTE: Location of Windows’ Volume control
is…
C:\Windows\System32\SndVol.exe
NOTE: Approximate .WAV file size for 5 min
of recording at 96 Kbps = 51 MB. The
same recording in WMA format = 3.5 MB.
Exit → see “Microphone” in “Recording”
section of this guide to start recording
with an external microphone. See also “DC
Offset in Windows” to ensure audio quality
is maximized.
Note that you cannot use Windows drivers and ASIO drivers at the same time. If you have ASIO drivers installed and then use any audio application that uses ASIO, that will block the Windows drivers.
