Dear Collective Wisdom,
I’m troubleshooting for a friend who’s in the process of setting up a home studio for voice actor work. The problem we’re trying to solve is insufficient volume in the resulting MP3 after export.
She has a Shure SM7B mic, plugged into a Shure MVi Digital Audio Interface (I might have called it a pre-amp, in the days before digital audio). From the MVi it goes into an iMac running OS X 10.11.5. We’ve been plugging it into the USB port at the left end of the keyboard; I don’t know if that port is different in any way from the ones on the back of the iMac. Audacity version is 2.1.2, downloaded in the last week.
I checked volume settings in various places (the Mac control panel, on the MVi, in Audacity) to make sure nothing was muted or set too low. The Mac appears to record and play back at normal volume using its built-in mic and speakers. MP3s recorded elsewhere appear to play at normal volume. But the files we recorded into Audacity and then exported as MP3s seem to play at about 1/2 volume (volume seems okay when playing back from within Audacity). I’ve tried playing them back in iTunes and in VLC.
In the wiki I saw that Audacity needs a LAME file installed for export to MP3 to work properly. I downloaded the LAME DMG file and ran the install, but I didn’t see the libmp3lame.dylib file anywhere in the Audacity directory (the LAME_Library_v3.98.2 etc folder was created, but it was empty). So I downloaded the zip file and unpacked that. Deleted and then (re-)created the LAME_Library etc folder in the Audacity directory, then placed a copy of the libmp3lame.dylib file there. Then following directions in the wiki, clicked on Audacity > Preferences > Libraries. Under “MP3 Export Library”, clicked on the Locate button to the right of “MP3 Library:”, which then gave me a pop-up window titled “Locate Lame”. In that window, clicked on the Browse button and navigated to the Audacity directory, where I found libmp3lame.dylib right where I’d placed it.
Aaaand… foo. The filename was grayed out, I couldn’t click on it to select it, and the Open button was also grayed out. However, my son pointed out that the “File type” drop-down box at the bottom of that window was set to “Only libmp3lame.dylib”; once he changed that to “Dynamic Libraries (*.dylib)” we were able to select the file and click on the Open button. (You may want to change the default there, it was rather confusing.)
So theoretically the LAME dylib file is now properly installed and recognized. But after doing another export, the MP3 file output is still quieter than other MP3 files, so I don’t think the dylib file was the main problem.
I’ll mention that when recording into Audacity, even with the gain on the active track bumped up to +36dB, the track appears to have plenty of spare room before it gets into the darker gray sections of the track display (I’m assuming that’s where distortion starts to occur?).
My preference with audio recording has been to start out with levels all set about halfway, then adjust as necessary. I don’t like starting with all the controls at max, because then there’s no place to go from there (except down, of course).
Any insight into how to control volume levels, either on the “signal in” side of things or on the “export to MP3” end, would be greatly appreciated.
Thanks.
