Ha ok seems this encoder only handles 16-bit
after what you asked last I ran a 24-bit alac to wav then to mac and again the dreaded ERROR: 1002 reared its head again
And since Audacity works from 32-bit that right there might indeed be the fly in the ointment
see below:
shan@shan-Aspire-XC-780:~/Desktop/trial$ mediainfo Rubycon\ Part\ 1.m4a
General
Complete name : Rubycon Part 1.m4a
Format : MPEG-4
Format profile : Apple audio with iTunes info
Codec ID : M4A (M4A /isom/iso2)
File size : 185 MiB
Duration : 17 min 15 s
Overall bit rate mode : Variable
Overall bit rate : 1 494 kb/s
Album : Rubycon
Track name/Position : 1
Performer : Tangerine Dream
Genre : Berlin School, Krautrock, Kosmische Rock, Cosmic Rock, Electronic, Electronica,
Recorded date : 1975
Writing application : Lavf58.49.100
Cover : Yes
COMMENT : 1975 UK Cassette
Audio
Format : ALAC
Codec ID : alac
Codec ID/Info : Apple Lossless Audio Codec
Duration_LastFrame : -4 ms
Bit rate mode : Variable
Bit rate : 1 472 kb/s
Nominal bit rate : 2 304 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : 24 bits
Stream size : 182 MiB (98%)
Default : Yes
Alternate group : 1
shan@shan-Aspire-XC-780:~/Desktop/trial$ ffmpeg -i Rubycon\ Part\ 1.m4a -c:a pcm_s24le Rubycon\ Part\ 1.WAV
ffmpeg version N-98601-g134a48a Copyright (c) 2000-2020 the FFmpeg developers
built with gcc 9 (Ubuntu 9.3.0-10ubuntu2)
configuration: --prefix=/home/shan/ffmpeg_build --pkg-config-flags=--static --extra-cflags=-I/home/shan/ffmpeg_build/include --extra-ldflags=-L/home/shan/ffmpeg_build/lib --extra-libs='-lpthread -lm' --bindir=/home/shan/bin --enable-gpl --enable-gnutls --enable-libaom --enable-libass --enable-libfdk-aac --enable-libfreetype --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-nonfree
libavutil 56. 57.100 / 56. 57.100
libavcodec 58. 98.100 / 58. 98.100
libavformat 58. 49.100 / 58. 49.100
libavdevice 58. 11.101 / 58. 11.101
libavfilter 7. 87.100 / 7. 87.100
libswscale 5. 8.100 / 5. 8.100
libswresample 3. 8.100 / 3. 8.100
libpostproc 55. 8.100 / 55. 8.100
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x562aa7618380] stream 0, timescale not set
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'Rubycon Part 1.m4a':
Metadata:
major_brand : M4A
minor_version : 512
compatible_brands: M4A isomiso2
artist : Tangerine Dream
album : Rubycon
genre : Berlin School, Krautrock, Kosmische Rock, Cosmic Rock, Electronic, Electronica,
track : 1
date : 1975
encoder : Lavf58.49.100
Duration: 00:17:15.77, start: 0.000000, bitrate: 1494 kb/s
Stream #0:0(und): Audio: alac (alac / 0x63616C61), 48000 Hz, stereo, s32p (24 bit), 1471 kb/s (default)
Metadata:
handler_name : SoundHandler
Stream #0:1: Video: mjpeg (Baseline), yuvj444p(pc, bt470bg/unknown/unknown), 1540x2492 [SAR 72:72 DAR 55:89], 90k tbr, 90k tbn, 90k tbc (attached pic)
Stream mapping:
Stream #0:0 -> #0:0 (alac (native) -> pcm_s24le (native))
Press [q] to stop, [?] for help
Output #0, wav, to 'Rubycon Part 1.WAV':
Metadata:
major_brand : M4A
minor_version : 512
IART : Tangerine Dream
IPRD : Rubycon
IGNR : Berlin School, Krautrock, Kosmische Rock, Cosmic Rock, Electronic, Electronica,
IPRT : 1
ICRD : 1975
ICMT : 1975 UK Cassette
ISFT : Lavf58.49.100
Stream #0:0(und): Audio: pcm_s24le ([1][0][0][0] / 0x0001), 48000 Hz, stereo, s32 (24 bit), 2304 kb/s (default)
Metadata:
encoder : Lavc58.98.100 pcm_s24le
size= 291311kB time=00:17:15.77 bitrate=2304.0kbits/s speed= 506x
video:0kB audio:291311kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000094%
shan@shan-Aspire-XC-780:~/Desktop/trial$ mediainfo Rubycon\ Part\ 1.WAV
General
Complete name : Rubycon Part 1.WAV
Format : Wave
File size : 284 MiB
Overall bit rate mode : Constant
Overall bit rate : 2 304 kb/s
Part/Position : 1
Director : Tangerine Dream
Original source form/Name : Rubycon
Comment : 1975 UK Cassette
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 00000001-0000-0010-8000-00AA00389B71
Bit rate mode : Constant
Bit rate : 2 304 kb/s
Channel layout : L R
Bit depth : 24 bits
Stream size : 284 MiB (100%)
shan@shan-Aspire-XC-780:~/Desktop/trial$ mac Rubycon\ Part\ 1.WAV Rubycon\ Part\ 1.ape -C5000
--- Monkey's Audio Console Front End (v 4.11) (c) Matthew T. Ashland ---
Compressing (insane)...
Error: 1002
further corroborated by the fact that I got nowhere fast with ttaenc either the message I get from Audacity and ttaenc is this:
_ttaenc -e Rubycon\ Part\ 1.wav
TTA1 lossless audio encoder/decoder, release 3.4.1
Copyright (c) 2007 Aleksander Djuric. All rights reserved.
For more information see > http://tta.sourceforge.net
File: [Rubycon Part 1.wav]
Error: not compatible file format
Total: [0/1, 0.0/0.0 Mb], ratio: 0.000, time: 0’00
FROM THIS 32-Bit FILE
shan@shan-Aspire-XC-780:~/Desktop/trial$ mediainfo Rubycon\ Part\ 1.wav
General
Complete name : Rubycon Part 1.wav
Format : Wave
File size : 379 MiB
Overall bit rate : 3 072 kb/s
Part/Position : 1
Audio
Format : PCM
Bit rate : 3 072 kb/s
Bit depth : 32 bits
Stream size : 379 MiB (100%)_
AND YET ffmpeg CAN encode to 24-bit from a 32-bit when ttaenc cannot so there must be a way to do likewise in Audacity maybe with mac and ttaenc if you catch my roundabout logic
or maybe not …
see:
ffmpeg -i Rubycon\ Part\ 1.wav -c:a tta Rubycon\ Part\ 1.tta
Input #0, wav, from 'Rubycon Part 1.wav':
Metadata:
comment : 1975 UK Cassette
date : 1975
album : Rubycon
track : 1
Duration: 00:17:15.77, bitrate: 3072 kb/s
Stream #0:0: Audio: pcm_s32le ([1][0][0][0] / 0x0001), 48000 Hz, stereo, s32, 3072 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (pcm_s32le (native) -> tta (native))
[tta @ 0x55ebbc8c05c0] encoding as 24 bits-per-sample
Output #0, tta, to 'Rubycon Part 1.tta':
PS: all these I have tested and work
ffmpeg -i - -c:a alac -sample_fmt s32p "%f" [24-bit]
ffmpeg -i - -acodec alac "%f" [16-bit]
ffmpeg -i - -c:a wavpack -sample_fmt s32p "%f" [24-bit]
ffmpeg -i - -c:a wavpack "%f" [16-bit]
ffmpeg -i - -c:a tta "%f" [16-bit]
shorten - "%f" [16-bit]
EDIT
Andrew here on Ubuntuforums came up with one alternative encoder which works with command provided by the handbook but it stays in 16-bit as Linux mac versions still not doing 24-bit; it is a partial solution certainly helps a bit
