Hello,
My post’s title says it all. I use “Export Audio → Export Multiple” all the time, and it’s one of the great features of Audacity. Now, I want to export around 100 tracks, with the same plugins on each of them. The plugins will be a De-esser, a De-plosive, and a Gate, all with the same settings.
My first instinct was to create a master output buss and put the effect on them, then export multiple tracks. But it won’t work that way. I’d have to export them one at a time. I can try to apply each effect to multiple tracks, one effect at a time, but it’s painstaking.
Any ideas on applying identical effects to multiple tracks when exporting? Thanks.
–john
Thanks mugen2x. I’ll try that again. I was under the impression that when exporting multiple tracks, it bypasses any FX busses, but I’ll put the FX on the Main Output and see what happens. Thanks again.
best, --john
This is narration for an audiobook, so it’s voice only. Each track is a book chapter. I need to apply the same effects to each one.
I’m able to apply the FX, but there doesn’t seem to be a way to apply the “Export Multiple Files” command. If I insert “Export as WAV”, it simply exports all as a single file, as if it is exporting a final song mix.
It says on the forums here that I can insert “Export Multiple” into the macro, but I do not see that listed as an option when I edit the macro. So, as a workaround, I will apply the FX to all tracks with the macro, then go to “File–> Export Audio” and choose “Multiple Files” (Split files based on Tracks). That will work.
Thanks.
–je
