Recording vinyl LP. Had problem w/one song. Re-recorded that song as second track. Deleted problem section. Moved on timeline. Copied and pasted new recording from track 2 into spot on track 1. Now, when trying to export multiple by label, stops at the inserted label and fails to export anything after that. What did I do wrong and/or, can I fix without re-recording? Thanks.
Please see the pink panel at the top of the page and tell us what version of Audacity you have (all three numbers).
You could try deleting the label track or tracks and relabel. Only the uppermost label track is processed.
If you already copied and pasted the retake audio into track 1, you should delete or mute the retake track 2 when exporting or it will be mixed in with the export.
If you are still stuck, please do View > Fit in Window and View > Fit Vertically and post an image of the project. See How to take a screenshot on your Mac and please see here for how to attach files: https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
