This is strange,
Whenever I export a file from Audacity to my desktop it will instantly disappear and will become invisible. It does not matter if I choose .wav, .mp3 or .flac, I see the file appear for a split second and then it vanishes.
If I use a third part app like “Quick Search” to find it, it shows up as a file on my desktop but if I search for it using file explore it does not.
That being said I can export it to any other folder, and it works fine.
This may be more of a problem with windows or one drive, but I thought I would just through it out there.
Audacity projects can be corrupted if you’re using cloud storage …
