Export options greyed out
When I select File > most of the options are greyed out. Cannot export at all.
I would like to expert to mp3, at the slowed-down pace I selected.
Windows 10. Audacity 2.1.0.
I am just a beginner–not doing anything complex.
I saw a couple of similar questions, but no answers.
Thanks
Is that a typo? The current version is 3.1.0 (Audacity ® | Downloads)
Which options are greyed out and which are available?
Only Import is available, and ITS options are greyed out as well.
What is / are “ITS”?
This could happen, for example, if you have no audio to export. If you were to Generate > Tone, for example, the options should work.
I have no idea why all of your import options would be grayed out.
I’m using 3.1.0 now.
File>Export is OK now. All options available.
(When I said ITS, I was emphasizing the word its. I was saying that the File>Import options are greyed out as well.)
I don’t know whether the file that I have open now fixed the problem, or updating to 3.1.0 fixed it, but I’m all set, thanks.
