Hello all,
I’m working on a project where I need to edit about 700 WAV-files.
When I use “Export multiple” Audacity automatically creates titles and track numbers for each file, even though there is no meta data in the original files.
Is there a way to export multiple files without creating any meta data?
Thank you.
I use EasyTag when I need to modify or remove metadata from a directory of audio files.
- Right click on one of the files and select “Open with EasyTag”.
- Select All.
- Click the “broom” (remove tags) button.
- Click the “down arrow” (Save to files) button.
All metadata has then been removed from all of the files in the directory. The entire process takes just 4 clicks.
