Have used Audacity for many years though not for a while. Just recorded an LP with multiple tracks. Unlike previous versions it seems I can only save the entire recording in 1 huge file. I have read the forum and help but that is no help. A screen here: Exporting multiple audio files - Audacity Manual Shows a FIELD Split Files Based On.
I do not have that in my Export Window.
I have Export Range>Entire Project which is default selected.
There is an option Multiple Files but it can not be activated.
All in all the Export window I have is missing Several Fields shown in the link above.
How in the world can I export to multiple files in order to name each file according to the song recorded. Was simple before.
Thanks
