Although Audacity already has an “Export Labels” command, it is quite limited in that it only supports one text export format, with only the label times and label text. If there are multiple label tracks, exporting the labels merge all labels from all tracks into one file.
This plug-in expands the functionality, allowing the exported file to also contain the track number and/or track name.
The output text / CSV file may be tab, comma or space delimited.
Controls:
Export labels to: Opens file browser to select the export name and location.
Allow file overwrite: [Yes / No (default=No)] When “No” is selected, the plug-in will not allow an existing text file to be overwritten. Note that regardless of this setting, the file browser will prompt about overwriting files if an existing file is selected.
Fields to export: The next 4 controls select which attributes of the labels will be exported,
Text formatting: Field separator [Tab / Comma / Space (default=Tab)] Selects whether the items in the text file are separated by tabs, commas or spaces.
When installed, the plug-in will appear in the Tools menu as “Export Labels…” exportlabels.ny (2.71 KB)
Just saying, I’m not a great user of spectral selection, I just know that initial label export, also export “low freq” anf “high freq” of these labels.
Just to push the button until the end and offer the full functionality, can you pretty please add these last column ? (maybe usefull for other users)
Now I can count these !
Understand. Label editing is probably not the most common use of audacity.
while in tracks this can benefit of a real ergonomic enhancement. (“suppr” “copy/paste” “move frome a track to another” …)
This is awsome plugin. It can help me a lot because I want to export labels to Excel, so csv format is good enough.
Can I ask for an improvement?
I would like to export time in human readable format like %H:%M:%S.%Mi (03:04:55.123) with possibilities of decimal separator depending on locales (OS settings) - instead dot use comma. It would be great to have a field “Time format” where I can define format.
And also it would be good not to export empty string when only time is exported.
Now it is
I am using LibreOffice Calc and have tried one of the formula from the link, and result isn’t correct. I will need more conversions. My locales use “,” as decimal separator, so during the data import float values are treated as “text” and interpreted incorrectly. Below, converted to number values are ok.
Of course, I can put it through python script to transform data to correct format, but I would like to avoid an extra steps. Just export in correct format from Audacity and import in LO Calc (or Ctr+C from exported file, Ctr+V in Calc) is what I am dream about
If you want some format other than seconds, then there must be extra steps somewhere. The choice is where to put the extra steps: in the Nyquist plug-in, in the Python script, or in LibreOffice. The choice is yours, but while we are happy to help, don’t expect someone else to do it for you.
