We are a few instructors here in Jönköping Sweden, with problems exporting labels.
When we do that (in the same way we have done for several years) the labels turns out in lounge tracks.
Track 1 (label 1) is about 55 min. 3 min music and 52 min quiet
Track 2 (label 2) is about 52 min. 3 min music and 49 min quiet
Track 3 (label 3) is about 49 min… etc.
Is it a bug? Or do I have to do in a new way in this latest version?
Please always tell us your Audacity version and version of Mac OS X, especially if you are reporting possible bugs. See the pink panel at the top of the page.
I will assume you are not talking about File > Export Labels… (which exports the label track as a text file).
If you are laying out audio clips in time, one clip per Audacity track, and doing File > Export Multiple… splitting files based on labels, yes it’s a bug from Audacity 2.1.1 onwards.
However, if you typed the names in the names of the audio tracks, and did not use labels, telling Export Multiple to split files based on Tracks, there would be no problem:
If this is the problem and you still want to use labels, use Edit > Select > All then Tracks > Mix and Render to render the audio to one track, and Export Multiple will work properly. Or, generate a short amount of silence at time zero, for each audio track that does not start at time zero .
No chance, I fear… But your English is quite good.
U have correct. I mean that audio labels, not the text ones. and I also mean multiple…
So what to do? A new version where the bug is fixed is coming? Or can I get an older version while I wait?
As I explained, your can add the text that you are currently putting into labels into the track names, instead of using labels, then it will work.
Or if you want to use labels, Edit > Select > All then Tracks > Mix and Render to render the audio to one track. If you only have one Audacity audio track, Export Multiple with labels will always work.
Unfortunately this is unlikely to be fixed for the 2.1.2 release which we are aiming for at the end of September.
However if it is easier for you, you can go back to the 2.1.0 release which does not have this problem: Audacity download latest version.
