Export is not doing anything
Whenever I export an audio, it doesn’t appear under the audacity file. The device that I am on is Windows
What???
Are you saying it’s not in the default folder when you go to File → Open?
What folder did you export to? What format? (MP3, WAV, etc.?)
Can you find it with Windows Explorer?
I don’t think it will show-up under Recent Files, unless you’ve previously opened it, not just saved (exported) it.
The format is WAV but when i click under the audacity button in file explorer it does not show up
WAV files are usually pretty foolproof…
Maybe a dumb question but did you look in the folder where you exported it? Or try Windows search.
Or try again and export to your documents folder (or somewhere you usually save stuff.)
