Export will not save changes to MP3 format. It creates the mp3 file without the project edits and changes.
Strange! If you haven’t done this, try exporting under a new name or in a different folder to make sure you aren’t re-opening or playing the old file.
Thanks. I’ve tried this and lots of other things, and I just have accepted the fact that it just does not work that way.
Have you tried something “drastic” like cutting-off the 1st half of the track?
Seems too obvious, but have you saved the project first, before exporting?
I once had a user tell me that Word was not saving his changes.
It turned out it was saving them, but he was opening a file with the same name in the Recent section of Quick Access, which wasn’t the newly saved file at all.
