"Export" directory should be saved per-project
(This is true for Windows. Now sure about other platforms.)
If I open Project 1, and export files, the directory selection dialog will default to the last directory exported to for any Audacity project. If I’m jumping between several projects, this gets annoying, as I’m constantly needing to change the export directory.
Ideally the last export directory would be stored within the project, and that could be used as the default when exporting.
The developers are currently rewriting the existing File Exporter and are considering various ideass. See:
