This morning I updated to 4.0, completed a project and tried to export audio to FLACs with separate files, which would not work. (Just got one big file).
Then I found the complaints, saw that 4.0.1 was supposed to fix export multiple, and updated to 4.0.1262721353.
Have tried this and it’s just the same - won’t export multiple.
In the “Export audio” dialog, beside “Type”, choose “Labeled regions as separate audio files” or “Tracks as separate audio files”.
Oh - that’s good - and it works. Must admit the words “labeled regions . .” caused me to completely overlook that option.
One point - I’m finding that the Export button at the bottom is off screen, and no way of moving the box up enough or reducing it’s size. Had to resort to closing the Windows taskbar.
Anyway, thanks for a rapid response.
