"Export as OGG" not working?
I have a very simple macro set up where it’s meant to select all the audio in a file, perform Stereo to Mono, and then Export as OGG again. Yet for some reason it’s not doing the exporting. Is there any way I can fix this?
Maybe you’re looking in the wrong place.
If you’re using a recent version of Audacity, see here: https://manual.audacityteam.org/man/directories_preferences.html
