I am trying to run my macro through the named pipe, but nothing is working.
I tried this one: ApplyMacrosPalette: Garble2
Use the name of the macro command as it appears in the Macro Editor. For example, the command for the “MP3 Conversion” macro is:
Macro_MP3Conversion:
Thank you steve, how come I was unable to find this in the docs? I searched high and low ![]()
Because Scripting covers almost everything that Audacity does, there’s a lot that could be documented, but because it is a relatively new feature the documentation is fairly bare-bones. It is also considered to be an “advanced” feature for enthusiasts, so there’s not much hand holding ![]()
A good tip: Try out commands as a macro before using them in a script. The commands used in macros are identical to those used in scripts.
(The command reference for both macros as scripting: https://manual.audacityteam.org/man/scripting_reference.html)
Another good tip: Try things out using the “pipe client” command line interface. It’s a good way to check that you’ve got the command syntax and arguments correct.
Final tip: Feel free to ask here on the forum if you get stuck. We’re more than happy to try to help ![]()
Thanks again, I am using C# to control audacity, nothing too advanced but I’m happy to share the code here once I get it up in github
