to be honest, i hate the new audacity. i’ve been using 1.3 for years and liked it just the way it was. i wish it were still available. now, “start to cursor” has an annoying “track” in front of it making it harder to find at a glance for instance. i REALLY hate that annoying extra popup you have to close to save a track that you can’t opt out of too. both of these annoying features really slow using audacity down.
that isn’t the biggest problem though. every time i open a track, trim the silence off the beginning and end, fade in and out of the track and make volume adjustments as needed and save it, i get another instance of audacity opening up after i close the 1st track, hit open, delete the original and open a second track for editing. i looked at my task bar and saw i had 8 instances of audacity opened! i never had ANY of these problems with the older version.
how do i make audacity stay as just a single window? having to close each new instance for every new track is an unbearable annoyance that not only further slows me down, but if i forget what is happening out of site, eventually it will crash my PC when i have 30 audacitys running at once.
i tried keyword searching “multiple instances of audacity” & “audacity opens new windows” to no avail. if anyone knows how to make that new track data “interrupter pop-up” shut up forever too, that would be appreciated as well. i know there’s no way to get rid of that “track” label that obscures “start to cursor”. even better, just bring the old version back. that’s what i know and love. i don’t like audacity 2.
