hello
ADCTY 2.4.1 Mac os 10.12.6
a lot of effect failed , i do not know what to do
thanks a lot for your light and time
hello
Did you look in Help > Diagnostics > Show Log to see if there was any more information?
– Bill
I’m guessing that the “AM pitchshifter” effect is from the SWH LADSPA plug-in set.
I would not expect the SWH LADSPA plug-ins to work in Audacity 2.4.1 because Audacity 2.4.1 is 64-bit and the SWH LADSPA plug-ins are 32-bit.
Also, Audacity’s built-in pitch shifter is likely to be a much better pitch shifting effect than the old LADSPA version.
Please note that Audacity 2.4.1 has now been superseded by Audacity 2.4.2: https://www.audacityteam.org/download/mac/
