i saved my project as aup. then closed out of audacity but i tried to open it back up cause i wanted to change something and this error pops up? i dont know if its cause i put [ ] in the title of the project or if its something else. i already tried changing the name of the file and it didnt help, Any suggestions? i realllllly want this song back
Please attach the AUP file so we can see it. Please see how to attach files to forum posts.
my bad i didnt know you could post it. Heres the file im talking about
Vacay prod. by TM.aup (33.6 KB)
[quote=“tavonjackson”]my bad i didnt know you could post it. Heres the file im talking about[/quote]
Thanks. Try the attached. I removed �� (SMILING FACE WITH SUNGLASSES) and the other Unicode characters or emoji in the metadata. Audacity doesn’t support these on Windows at present so you will have to do without them.
[quote=“Gale Andrews”][quote=“tavonjackson”]my bad i didnt know you could post it. Heres the file im talking about[/quote]
Gale[/quote]
youre a life saver! howd you access the metadata? just incase this issue comes up again
I opened the AUP file in Notepad++, making sure that View > Word Wrap was off so I was looking at the line number indicated in the error. The metadata entries start with
<tag name="
Notepad is less safe to use. Unless you are careful to remove all Unicode characters, including those Audacity can handle OK, Notepad will save as UTF-8 with “BOM” as it’s known, and then you have to use Notepad++ to convert it to back to UTF-8 without BOM so Audacity can open it.
