Error opening recording device - MacMini OSX10.13.6
Hello Audacity
First I admire what you do. Very impressive program. And support.
Trying to capture streaming audio from Safari
Mac Mini (Model identifier Macmini7,1
OSX 10.13.6
start Safari, go to page
start Audacity
start playing audio track
Audacity
Click RED dot record
Error Opening recording device
Error Code: 0 Success
The manual says
“this means there is a problem with your Audacity, operating system or sound device recording settings, where xxxx is replaced by a numeric code” Look up code, dead end.
Suggestions?
bye
eric
It’s probably this: https://forum.audacityteam.org/t/no-recording-level/51788/1
Thanks for the quick reply.
No microphone option.
I’m starting to wonder if this just won’t work BECAUSE it is a “Mac Mini”?
bye
eric
macOS does not directly support recording streaming audio. You need additional software (or a "loopbac cable) to give the Mac that ability.
See: Tutorial - Recording Computer Playback on Mac - Audacity Manual
SUCCESS REPORT
it worked!
Inelegant but it works. (having to switch preferences back and forth)
Doesn’t matter. open source and it works.
Nice.
Also EXCELLENT documentation!
Thanks for the help
bye
eric
Forgot to mention.
Several solutions were offered.
I used the “SoundFlower” option.
bye
eric
