Error: Not well-formed(invalid token) Line 5858 [SOLVED]
Please help,
After a computer crash i tried to recover my project an i got the: Error: Not well-formed(invalid token) Line 5858.
I’ve attached my .aup file.
I’m using windows 8 and the version of audacity im using is: 2.0.5 and i think i used the .exe installer
Hope some miracle worker can fix my problem…
Thanks!!
Rauw 2.0 beta.aup (186 KB)
P.S.
I also added my autosave file and my log file after trying to recover my project.
Rauw 2.0 beta - 2014-08-04 16-33-24 N-372.autosave (293 KB)
log file Error line 5858.txt (1.96 KB)
I’ve fixed the end of the file for the line error.
I assume the previously saved AUP file would open about 60% of your project.
How long is that track in total? Be aware if you record over about 13.5 hours at 44100 Hz in 2.0.5 then the saved AUP file or the AUTOSAVE file will reopen the entire project as “orphan block files”.
If that happens, you would have to force quit Audacity in Windows Task Manager to preserve the data then try opening the project in the latest 2.0.6-alpha (or 2.0.6 when released). See: http://wiki.audacityteam.org/wiki/Recording_length#long .
Rauw 2.0 beta - 2014-08-04 16-33-24 N-372.autosave (299 KB)
Thanks a lot!! You made my day. :smiley:
