Okay I’m new to this kind of stuff so please have patients with me here. So I was recording something when mid-recording my computer turned off. Usually I could just do the “Recover Projects” thing but it didn’t work this time. It just says “Error: not well-formed (invalid token) at line 5199”. I’m not sure what to do about this, can I get it back in one piece? It was pretty important. If there is anything you need to know just ask me for it and I’ll do it…you might have to guide me on how to do it but I’ll try. I use windows 7 and Audacity 2.0.3. Thanks!
And just in case you need it, here is the log
00:09:41: Audacity 2.0.3
00:09:44: Trying to load FFmpeg libraries…
00:09:44: Trying to load FFmpeg libraries from system paths. File name is ‘avformat-52.dll’.
00:09:44: Looking up PATH environment variable…
00:09:44: PATH = ‘C:Program FilesTrend MicroAMSP;C:Program FilesCommon FilesMicrosoft SharedWindows Live;C:Program Files (x86)Common FilesMicrosoft SharedWindows Live;%SystemRoot%system32;%SystemRoot%;%SystemRoot%System32Wbem;%SYSTEMROOT%System32WindowsPowerShellv1.0;c:Program Files (x86)ATI TechnologiesATI.ACECore-Static;c:Program Files (x86)Common FilesRoxio SharedDLLShared;c:Program Files (x86)Common FilesRoxio SharedDLLShared;c:Program Files (x86)Common FilesRoxio Shared12.0DLLShared;C:Program Files (x86)QuickTimeQTSystem;C:Program Files (x86)Windows LiveShared;’
00:09:44: Checking that ‘’ is in PATH…
00:09:44: FFmpeg directory is in PATH.
00:09:44: Checking for monolithic avformat from ‘avformat-52.dll’.
00:09:44: Error: Failed to load shared library ‘avformat-52.dll’ (error 126: the specified module could not be found.)
00:09:44: Loading avutil from ‘avutil-50.dll’.
00:09:44: Error: Failed to load shared library ‘avutil-50.dll’ (error 126: the specified module could not be found.)
00:09:44: Loading avcodec from ‘avcodec-52.dll’.
00:09:44: Error: Failed to load shared library ‘avcodec-52.dll’ (error 126: the specified module could not be found.)
00:09:44: Loading avformat from ‘avformat-52.dll’.
00:09:44: Error: Failed to load FFmpeg libraries.
00:09:44: Error: Failed to find compatible FFmpeg libraries.
00:11:30: Error: Could not parse file “C:UsersrobertAppDataRoamingAudacityAutoSaveNew Project - 2013-06-26 18-33-24 N-181.autosave”.
Error: Error: not well-formed (invalid token) at line 5199
