After much ado and following forum advice, I finally managed to have ACX check show in the plug-ins and unfortunately after I hit ‘enable’ I had this message pop up:
Effect or command at Users/Macbook/Library/Application Support/audacity/Plug-Ins/acx-check.ny failed to register:
ill formed nyquist plug-in heade.
The error message means that there’s something wrong with the file “acx-check.ny”. I’d suggest that you try downloading it again. If you still get the same problem, please attach the file to your reply so that we can see what’s wrong with it.
