Hi there,
Audacity 2.4.2 on Window 10 1803 and confirmed same issue on Windows 10 2004
I’ve enabled microphone access in Privacy settings as per the sticky but get ‘Error code: -9999 Unanticipated host error’ when i hit record.
Microphone works in other applications on the same device
Mic is enabled in Control Panel / sound
Sample rate is set to 44100
Any suggestions appreciated
Thanks
Stereo/Mono has to match, too.
What is the microphone and how is it connected?
Are you using cloud storage anywhere in your system?
Audacity is not a fan of cloud drives and internet storage.
It’s an MPOW HC6 USB headset, and though it is two-channel I get the above error whether it is stereo or mono.
All local storage.
Thanks - keep the suggestions coming!
5
Hi there
Many Thanks - should be attached
audacity_device_info.txt (7.9 KB)
