Error Code -9999:: Error opening recording device
Win 11 25H2
If I disable my record device for security reason, AU4 beta 2-4 continues to show a modal popup reporting issue about the rec missing device (Host error).
Nonsense and bothersome… 1st because interrupt the use and interactivities with the current working project; 2nd because when I force the rescan for audio device the App should detect the missing device and disable rec functionalities, warning only once the missing “Host” and not break continously with a unuseful popup.
Thanks
