Hi All,
Audacity 2.3.0 on Windows 10 on a Dell Optiplex 3020. Attempting to record using a Logitec A-5572A USB microphone adapter and get the following error:
Error opening recording device.
Error code: -9999 Unanticipated host error.
I’ve followed the steps in the help files for this error, including checking that microphone is enabled in the Windows privacy settings.
Format on the mic in windows is set to 1-channel, 16 bit 44100 Hz. I can see audio on the bar graph in the windows sound settings. Skype works and I believe the built in voice recorder app works.
I’ve tried MME and DirectSound. WASAPI gives me error -9997 when I try to record.
The front-panel microphone input also fails to open with error -9999.
Any clues what to do at this point?
Regards,
Glenn
Audio Device info below:
Default recording device number: 1
Default playback device number: 4
Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Recording channels: 2
Playback channels: 0
Low Recording Latency: 0.09
Low Playback Latency: 0.09
High Recording Latency: 0.18
High Playback Latency: 0.18
Supported Rates:
Device ID: 1
Device name: Headset Microphone (2- Logitech
Host name: MME
Supported Rates:
Device ID: 2
Device name: Microphone (Realtek High Defini
Host name: MME
Supported Rates:
Device ID: 3
Device name: Microsoft Sound Mapper - Output
Host name: MME
Recording channels: 0
Playback channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 4
Device name: Headset Earphone (2- Logitech U
Host name: MME
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 5
Device name: Speakers / Headphones (Realtek
Host name: MME
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
    352800
    384000
Device ID: 6
Device name: Primary Sound Capture Driver
Host name: Windows DirectSound
Low Recording Latency: 0.12
High Recording Latency: 0.24
Supported Rates:
Device ID: 7
Device name: Headset Microphone (2- Logitech USB Headset)
Supported Rates:
Device ID: 8
Device name: Microphone (Realtek High Definition Audio)
Supported Rates:
Device ID: 9
Device name: Primary Sound Driver
Low Playback Latency: 0.12
High Playback Latency: 0.24
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 10
Device name: Headset Earphone (2- Logitech USB Headset)
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 11
Device name: Speakers / Headphones (Realtek High Definition Audio)
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    176400
    192000
Device ID: 12
Host name: Windows WASAPI
Low Playback Latency: 0.003
High Playback Latency: 0.01
Supported Rates:
    48000
Device ID: 13
Device name: Speakers / Headphones (Realtek High Definition Audio) (loopback)
Low Recording Latency: 0.003
High Recording Latency: 0.01
Supported Rates:
Device ID: 14
Supported Rates:
    48000
Device ID: 15
Device name: Headset Earphone (2- Logitech USB Headset) (loopback)
Supported Rates:
Device ID: 16
Recording channels: 1
Supported Rates:
Device ID: 17
Supported Rates:
Selected recording device: 17 - Microphone (Realtek High Definition Audio)
Selected playback device: 14 - Headset Earphone (2- Logitech USB Headset)
Supported Rates:
