Caxtin
1
Windows 11 / Audacity 3.7.4
Hello folks, attached is a Cool Edit Pro’s Equalizer settings for an audio track. What would be the equivalent of this attached, in Audacity?
And also, how could I perform a batch process (Equalize) on multiple audio files?
Cheers
Trebor
2
Filter curve EQ …
import this preset into filter curve , adjust to taste, then save as preset
approx.txt (441 Bytes)
NB: Audacity’s native equalizers are not adjustable in realtime
I would install a realtime equalizer plugin like the free version of TDR Nova.
Batch process in Audacity is called macros
Caxtin
3
Thank you so much, well appreciated.
system
Closed
4
