I am getting back into voiceover work and am having trouble with filter curve and EQ settings. It doesn’t seem that there is a way to adjust EQ in real time. Any suggestions of how to get your sound to be its best? Is there another program needed at playback for EQ?
Wow - many thanks. Do you have a preference? I installed the first one. Also, how easy is it to integrate it into Audacity?
TDR Nova has a real-time spectrum, showing either pre-EQ audio, or after-EQ
Thanks! I appreciate it.
Quick update. I have been playing with TDR Nova for a few hours and don’t see what it does. Threshhold on or off doesn’t seem to make a difference, and the EQ and high pass filter adjustments don’t seem to have much effect. At least I know.
You have to select TDR Nova from the real-time effects menu (far left) for it to function in real-time as you play the track.
I see what you mean. Many thanks.
