It would be good if there was a way to configure the defaults for multiple users.
I suggest there is a simple way to achieve this by allowing admins to save a audacity.cfg in the Audacity program files folder. Then if when the software is launched, there is no audacity.cfg in the Application Data\Audacity folder, the software will copy the audacity.cfg from the program files folder if it exists.
This simple change would allow us and many other schools to pre-configure lots of settings (particularly switching off auto-update) without having the configure our networks to copy the audacity.cfg to all users’ application data folders in advance.
If you make a folder called Portable Settings inside of the Audacity folder, Audacity will look for the cfg files in there (or create them if there are none): https://manual.audacityteam.org/man/portable_audacity.html
From what I’m understanding, it seems that if the Portable Settings .cfg file exists, that’ll override all settings that a user may have configured themselves. My use case for Audacity is for a student computer lab where students use it during class. I’d like to be able to configure the software so that it doesn’t give a bunch of pop-ups to students when they sit down for class. So getting rid of the splash screen, disclaimer popups, and the update window.
I see that I can configure these settings using a cfg file, however it seems that once a Portable Settings file is detected, the program will only look there for all configuration settings. Is it possible to have administrator control over only a few options while leaving the rest to the user? Generally I would do these configurations using CLI options during the install, but Audacity doesn’t seem to support adjusting app settings that way.
