Need help. El Capitan 10.11.1 and Soundflower 1.6.6 Audacity 2.1.1 crashing. I have not been able to record since updating to El Capitan. Discarded audacity.cfg. No good results. Am I missing something here? Any others with same issues? Please let me know.
Audacity doesn’t support El Capitan?
http://audacityteam.org/download/mac#sysreq
Scroll to System Requirements.
Do you know if there plans for OS X 10.11 (El Capitan) development for Audacity software?
Win10 has the same problem. I Believe Audacity 2.1.2 should support both. (I’m not a developer).
Audacity 2.1.1 and later do support El Capitan. The system requirements for 2.1.1 stop at OS X 10.10.x because at the time 2.1.1 was released, El Capitan had not yet been released and was an unknown quantity.
Audacity 2.1.1 requirements similarly did not mention Windows 10 because Windows 10 had not yet been released, and because although we suspected there would be problems, we were not clear what they might be.
Audacity 2.1.2 will support Windows 10, but with a serious proviso that all enabled devices must have Windows 10-compatible drivers designed for the device, or Audacity might not see any audio devices at all. PortAudio has a possible fix for this so I expect us to update PortAudio as soon as possible after 2.1.2 is out.
Are you sure 2.1.1 is crashing because of Soundflower 1.6.6? I suspect that is not the cause. Please open /Applications/Utilities/Console.app then look at the System Diagnostic Reports. Attach the latest Audacity crash report from there. Please see here for how to attach files: https://forum.audacityteam.org/t/how-to-attach-files-to-forum-posts/24026/1
You are correct that Soundflower 1.6.6 does not work in El Capitan. See Tutorial - Recording Computer Playback on Mac for what you need to do, which in short is to make a copy of “Soundflowerbed” that came with Soundflower 1.6.6, use the “Uninstall Soundflower.scpt” to uninstall Soundflower 1.6.6, then install Soundflower 2.0b2.
Thanks Gale,
Here is may console log from latest run. After successfully unpacking the 2.0b.2 version of Soundflower…
11/22/15 1:19:24.085 PM com.apple.xpc.launchd[1]: (net.sourceforge.audacity.300832[478]) Service exited due to signal: Terminated: 15
11/22/15 1:19:56.918 PM Audacity[487]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.1 instead of 10.11.1. This is not a bug in Gestalt -- it is a documented limitation. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
11/22/15 1:19:56.919 PM Audacity[487]: 0 CarbonCore 0x97fa7f1d ___Gestalt_SystemVersion_block_invoke + 135
11/22/15 1:19:56.919 PM Audacity[487]: 1 libdispatch.dylib 0x9583a7e7 _dispatch_client_callout + 50
11/22/15 1:19:56.919 PM Audacity[487]: 2 libdispatch.dylib 0x9583a6c3 dispatch_once_f + 78
11/22/15 1:19:56.919 PM Audacity[487]: 3 libdispatch.dylib 0x9583bf4d dispatch_once + 31
11/22/15 1:19:56.919 PM Audacity[487]: 4 CarbonCore 0x97f239e1 _Gestalt_SystemVersion + 1047
11/22/15 1:19:56.919 PM Audacity[487]: 5 CarbonCore 0x97f2318a Gestalt + 154
11/22/15 1:19:56.919 PM Audacity[487]: 6 Audacity 0x00462ae2 _Z14UMAInitToolboxtb + 50
11/22/15 1:19:57.556 PM Audacity[487]: 13:19:57.556 WARNING: 140: This application, or a library it uses, is using the deprecated Carbon Component Manager for hosting Audio Units. Support for this will be removed in a future release. Also, this makes the host incompatible with version 3 audio units. Please transition to the API's in AudioComponent.h.
11/22/15 1:20:05.680 PM Audacity[487]: 13:20:05.680 WARNING: 140: This application, or a library it uses, is using the deprecated Carbon Component Manager for hosting Audio Units. Support for this will be removed in a future release. Also, this makes the host incompatible with version 3 audio units. Please transition to the API's in AudioComponent.h.
11/22/15 1:20:11.493 PM Audacity[487]: CGContextRestoreGState: invalid context 0x0. If you want to see the backtrace, please set CG_CONTEXT_SHOW_BACKTRACE environmental variable.
11/22/15 1:20:11.738 PM com.apple.xpc.launchd[1]: (net.sourceforge.audacity.300832[487]) Service exited due to signal: Abort trap: 6
11/22/15 1:20:17.045 PM ReportCrash[489]: Saved crash report for Audacity[487] version 2.1.1.0 (2.1.1.0) to /Users/carmo/Library/Logs/DiagnosticReports/Audacity_2015-11-22-132017-MacBook-Pro.crash
We need the diagnostic report itself. Please attach “/Users/carmo/Library/Logs/DiagnosticReports/Audacity_2015-11-22-132017-MacBook-Pro.crash”.
Also tell us exactly what you do from launching Audacity, step by step, until Audacity crashes.
I’ve attached a Word document since I could not locate the file other than using Console.
As far as Audacity actions, I launch Audacity, click monitor to see signal, then Record… it then stops abnormally.
Hope this helps find the problem. Thanks for your concern.
There is nothing attached. If the report says “spinlock” in the crashed thread, and from your description below, we probably don’t need to see it.
Is Transport > Sound Activated Recording enabled? If so that may well crash in 2.1.1. That bug is fixed now in our source code. If you want to use Sound Activated Recording I recommend you try “Audacity Mac OS X 2.1.2 RC1 DMG (for testing)” posted on http://www.fosshub.com/Audacity.html/.
If you are not using Sound Activated Recording, you may need to stick to recording one track only, and don’t have more than one project window open at a time. When you have recorded the one track, export it, Audacity > Quit Audacity and restart Audacity. That may make it more stable.
Gale,
Re-installed Audacity per your instructions… all is OK. Many thanks for your help. Sound activation does not work, but it isn’t necessary.
Thanks again for all your assistance.
I’ll close and lock this given I understand you can now record from Soundflower.
If you receive more Audacity crashes, please start a new topic with as much detail as you can.
