I teach Spanish. Every semester students submit an audio recording of them using the language.
Here is how I go about correcting their grammar and pronunciation:
- I import their recording into Audacity.
- I have set up a keyboard shortcut (Shift + L) for Generate Silence.
- About every 5-10 seconds in the recording, basically between their sentences, I insert 5 seconds of silence using my keyboard shortcut. To do this I move the cursor line forward with the right arrow key. When I get to a small gap between sentences, I then hit Shift + L then Enter to insert 5 seconds of silence.
- After inserting these gaps of silence, I then listen to the recording with my recording headset. In the 5 second gaps of silence I correct their pronunciation and grammar.
- After this point, I export to .ogg and email the audio file with the corrections to them.
I have up to about 75 students every semester. Each recording is 3 to 5 minutes in length. As you would imagine the part where I insert silence every 5-10 seconds gets a little tedious and takes a long time.
I tried to make multiple cursor lines in the recording at once to then hit Shift + L then Enter once. However, I was unsuccessful. If anyone has any ideas on how inserting all of these silent segments could be made more efficient, I will be quite grateful. Thank you
