I’m using the attached clip as the subject for my first adventure with Truncate Silence.
I understand nobody is likely to repair this clip to studio performance, but as near as I can tell, Truncate Silence does nothing. I would expect it to collapse tiny segments of very low volume to almost zero time, but it appears to have no action no matter what user values I choose.
The goal is to produce different trash.
Noise Gate works perfectly correctly, but that’s not the action I want. I don’t want to “clean up” the low volume snippets, I want them to vanish—or as close as possible.
The minimum “detection” duration is 0.001 seconds (1 ms).
The minimum “Truncate to:” (“action”) is 0.0 seconds (remove the detected silence entirely / collapse to zero).
