Editor improvements
First of all : Audacity 4 is already great!
I’m testing it now (alpha version of november) and here are already 4 improvements that can be made :
  • There is a bug in copy paste : i’ve set 4 beats in a music measure and when i’m copying it to the second, the first beat is cropped and the rest isn’t positioned right (moved to the left)
  • If i make a new track, the popup buttons (stereo, mono) won’t dissappear after clicking them
  • align the vertical line (pointer) to the beginning of a music measure when clicking nearby
  • VST3 support :slight_smile:
I must congratulate the team with the workflow of the program : I’m used to work with Logic (and that’s really easy) but but some things I find easier to do in Audacity 4 :slight_smile:
cc @dozzzzer @mugen2x
that’s intentional, to allow you to quickly add multiple tracks.
try turning on snapping
I believe that already is in the latest master build, perhaps not the alpha
Thanks for the reply. Only I find it strange to add multiple tracks at once as a standard option. I think most editors will add one track at a time. :slight_smile:
Just came up with an idea : in a track add a record button to start recording in that track (like in logic or ableton). It’s a good safety feature so that you must select the correct track to record in.
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
