I’d like to suggest an easier way to
Move Focus To Next Track
Move Focus To Previous Track
Although Down/Up arrows do work fine,
and we can assign other keys that we prefer,
I would love to be able to use
Edit> Preferences> Mouse>
Any> Move Focus To Next Track/Move Focus To Previous Track> Wheel-Rotate
to move from one track to another quickly an very easily.
And have Alt-Wheel-Rotate for Scroll up or down, since I think this may
generally be used less than the more frequently used switching of focus between
a track and its label track. (Not sure about that.)
The reason being that I think many love to jump between tracks
often and quickly and easily,
without having to move the arm across the keyboard each time to the up/down keys,
or having to click into the audio track or label tack to select it.
I notice with lots of detailed work between a track and its label track that I’m having to
consistently do a lot of arm movement over to the Up/Down keys to switch focus between the
track I’m working on and its label track.
It’s just a thought. I think many would enjoy this.
By the way, and chance that what I see is called mouse bindings may be configurable?
My solution for now is that I assigned the keys
Alt+D to Move Focus To Next Track
Alt+S to Move Focus To Previous Track
…makes it a little easier to jump back and forth between audio track and label track.
Maybe I’m overlooking another option?
Thanks for any ideas.
frew
