DX Lite Reverb Replacement Suggestions
I have been using DX Lite Reverb for years with Audacity. Very simple to use - it was all I needed. The newest Version of Audacity did away with it and it cannot be downloaded anymore. Audacity default reverb too complicated for me. Any suggestions for a really simple plugin I can use? Thanks for any help.
Anwida’s algorithmic reverb is alive and well and available in 64-bit VST3 …
SPATIO Light - Free Reverb Plugin (VST, AU) - ANWIDA Soft (free)
Thank You I will try it
