Can you add these effects with simple beats to a existing track? I don’t have the instruments to play & record. I’m fairly new to this.
You probably want a MIDI application (which Audacity is not) or a DAW which will support MIDI and virtual instruments.
I will look into the options you suggested, thanks for that.
