Drumloop skipping
When I use Audacity to “record what I hear” off a dj software, it seems to skip through the looped drumbeat until I mix in the 2nd track, then it goes back to it’s normal tempo. Is there a setting that I may have not adjusted?
Transport > Transport Options > Sound Activated Recording could cause this.
Thank you so much for your reply, seems like the logical solution to deactivate it. I will give it a go once I’ve reinstalled it on the new PC :+1:
