How do I download in mp3 format?
What format is it now? Audacity won’t do on-the-fly conversions.
And do you really mean download a file (which doesn’t require Audacity)?
Or do you want to record something with a microphone, or digitize a vinyl record, etc.?
Or, record something on the Internet that’s playing on your computer?
No, I really mean download a file I made in Audacity to my computer in mp3 format. The file is currently labeled .aup3. When I try to upload it to Invideo.ai it does not accept that file type. When I go into properties it says it is an mp3 file. I don’t know why Invideo won’t accept it.
That would be a question for Invideo. What are their format requirements? do they say MP3 is OK? (It is a fairly universal audio format.)
Does the MP3 play OK on your computer, in Windows Media Player or whatever?
And that would be uploading. ![]()
To “download” an audio track from Audacity you need to “export” it.
Select “export” from the “File” menu and configure your settings for
your mp3 (quality and path etc,), for example:
